Nevemind the gfx problem... get that ancient Datasentry battery off there before it leaks and does some real damage.
Can it be replaced with a cr2032?
Thanks all for the advice, I'll be doing some measuring tonight. I know a prior owner possibly did some troubleshooting on the board, and I noticed some of the IC's are marked with a red paint stripe. Is this factory? Some look like factory markings, some not. Pics attached.
i used to have a q-bert in my arcade that used to give me fits..i had to use a fibreglass brush and take the roms out and polish the legs on the roms that went into sockets...( WARNING...if you do this take your OLD sweet time removing them so not to break legs off the chips..and slowly polish the legs till they are clean and shiney )
if you feel you can do that just polish the legs shiney and slip them back in the sockets... thats what used to cause mine to have a fit till they got polished...then it worked fine
my 2 cents!
END OF LINE.
Daniel.
I must have a horseshoe up my ass because I replaced and socketed D10 just before pulling the rom out at E10-11 an brushing off the legs with a fiberglass brush... Popped the board in for a test, and viola. Thanks for the advice all!
