Q*Bert Monitor
Braido
California
Can anyone tell me what the orginal monitor was in the Qberts? Was it horizontal or vertical and what the number is?
Monitor
I have 2 of them setting here and they are both vertical frames with 4900 monitors. I am pretty sure one of them is the origional monitor.
I am having sync problems, do you know anything about qbert sync problems?
Yep.....my Q-Bert had a 4900 in it too....
Do you have sync problems with a newer monitor? If so...here might be a solution...it worked for me on my newer monitor.
Subject: trivial QBert sync inversion hack
Newsgroups: rec.games.video.arcade.collecting
Date: 1998/10/13
Joe Britt and I came up with a trivial hack to convert Q*Bert
boards to negative sync, and lets you generate combined H/V
sync as well. It turns out that J14 (a 7407) is only used
as a sync buffer. Replace it with a 7406, which is an inverting
open collector buffer. The sync is then active low, and since
it is open collector, you can 'wire-or' the outputs and get
combined H/V sync.
Date: 1998/10/13
combined H/V sync.
I put a new monitor in the Q*Bert and now i am having sync problems. Nothing too bad but the image does wander a little.
I am still having some problems with my Q*Bert monitor syncing up. The monitor i have in my Q*Bert machine is a Orion OC-2012 Vert. Anyone have any ideas? The monitor is brand new.
Thanks, i'll give that a shot tomorrow I don't have Qbert at home here, (doing a reno at the house) i'll let you know how i make out.
