Got this thinking it would work in a original q-bert but it is a different edge connector. Anyone know what one this is (standard jamma)? Also what would it take to make it work in a regular q-bert?
Yes it is quite different, not Jamma, it is a 44 pin connector, if you want the pinouts email me at dmillikan "at" juno.com and I'll send them to you.
Dick
You'd have to build your own and the audio is built in the main board on the clone. Might be worth it if you don't have the rest of the Qbert boardset but you will have to make some mods for sure.
This version of the board has no speech but the gameplay is good.When i had mine i was very tempted to populate the empty locations on the board to add speech as the board supports speech they just chose not to populate the speech section.I have read also there is a way to enable the knocker with this board as well.Much easier to score a real board.
