Q*bert harness help, where does this part go?
The Drizzzl
Reading, Pennsylvania
Ok so i got my qbert harness. Thought it was the last part i needed. Well I don't have anything that plugs into the video on the monitor. and i don't have anything that plugs into the controls. I have three connectors not leading to anything. The one i know goes into the controls i just dont have the end that goes from the controls into it. The other two are labeled A10-P4 and A7-P1. I am assuming A10-P4 is for the monitor cuz there are 9 pins but i don't have the connector that goes into the monitor. And the other i was thinking maybe the knocker? The knocker i dont care about because i am running Qberts Qubes. But if anyone can help me out here it would be much appreciated. If someone could give me the pinouts on the monitor and controls I could make the connectors myself. Thanks in advance.
the connector that goes to the monitor is separate...it runs from the chassis to the filter board..
also the qbert harness is 2 pieces....one that runs inside the cab and the other runs on the door for the boards. make sure you have both pieces.
basically, the inside harness runs up to the top of the filter board filling it out...and the door harness connects all the boards and fills out the bottom of the filter board....and there is one spot for the monitor.
if this is the one you bought in the FS section from chips4sale (mousetrap) then its not complete, it was only 1/2 the harness.
I got another one thats full. It fills out the filter board (minus one spot) plus i have the one that runs up the other side of the cabinet from the power to the marquee light and speakers.
So is the monitor spot on the filter board the top left? Because that is empty on mine.
If the connector that I was asking about isn't for the monitor then what is it for?
The connector that i thought was for the controller is labeled A9-P2. That is on the wiring that runs up the other side of the cabinet.
Ok let me correct myself here. A9-P2 is on the side that runs from the filter board. And i found some pictures that show that A7-P1 is for the knocker. It also shows a tester but i cant tell which of my other two connectors goes to that and which goes to the controls
a7-p1 = knocker
a10-p3 = coin door
a10-p4 = service panel
1 runs up for the ballast
1 runs up for the speaker
the rest go down to the brick.
awesome, thanks! Now i need to figure out which wire is which control. Also, do i have to have the service panel wired up for it to work?
Yes, if you dont it will stay stuck in test mode. The service switch is normally closed for game mode so at minimum you can just tie the service wire to ground if you dont have a service panel yet.
i have a extra service panel with only a coin counter on it i believe...if you want it pm me...riptor might have the parts to complete it.
