Q*Bert Bezel Removal?
morbidboy
Minneapolis, Minnesota
It looks hazy in and out so I want to take it out of the cab to clean it. Looked online and in the instructions but can't find a way to take it out... suggestions?
Reach inside the coin door, unbolt the control panel from the bottom, remove control panel, lift the glass. The control panel overlaps the glass and holds it in place.
If it is an original glass one I'd be hesitant to clean the back of the painted areas though. Especially if you use an abrasive, the paint will start peeling and flecking off. :(
