Inside is a bit dirty. Most of the metal parts are rusty or slightly corroded. The original power harness is still there, as is the original transformer brick. All the original PCBs, the knocker, and the PCB harness are missing. Just the Time Soldiers harness and power supply are left:
I think this one will look great when its done! My work is a little ahead of this post, but am not done with this restoration as I write this. Ultimately, I will probably go with a JROK board for this cab unless I can score a PCB set and harness by the time I get around to wiring it up.
