Putting a Track and Field and Hypersports in the same cab
timbre
Washington
Has anyone out there messed with the idea of putting both a Track and Field and Hypersports in the same cab? I think the harness is the same. Would there be a way to mount both boards, build a custom harness so you could switch select which game would play?
I've done it with a parallel port switchbox for a friend's game in the past... not the most elegant solution, but it got the job done.
So what all are you switching with the parallel switcher? Entire harness or just certain parts. I was worried about doing something where it could feed from one board to the other and damage things.
well it all depends on if you want to just play with 2 players or 4 players?
can you solder?
are you into some work? lol
i have a cocktail cab that i am going to be putting in track and field, hypersports and 88 games and i have figured out how to do them all with a switcher on paper.
i can mail you a copy of my notes.
Easy to do with MAME... ;)
I put the following games on mine:
Track and Field
Hypersports
88 Games
Gold Medalist
Field Day
Recordbreaker
