Purchasing Caps at Mouser - couple of questions
Bullwinkle
Rochester, New Hampshire
OK, I've looked through a bunch of threads on here and gotten a general idea on what caps to get. But I have a few questions before I create some projects on their site and place an order. I'm looking at Nichicon caps.
1: I've read many times that it's important to use hi-temp caps when replacing hi-temp caps, but many use hi-temp cap to replace a standard caps. Is there any real benefit to using a hi-temp cap where a standard cap is called for?
2: Mouser has multiple "series" of caps for the same value. For example:
  • PW Series: Miniature Sized, Low Impedance, High Reliability For Switching Power Supplies
  • KT Series: For General Audio Equipment, Wide Temperature Range
  • ST Series: 7mmL, Wide Temperature Range
In many cases there is a cost difference. Is there a specific series I should look to purchase?
Any insight would be greatly appreciated.
-tom
could you give us some examples of high temp caps on common boards?
Most of the common (older) monitors didn't really specify high-temp caps. You don't start seeing that specified until newer monitors. I recently posted a cap kit list I made for a K7501, and it shows quite a few high-temp caps:
http://forums.arcade-museum.com/showpost.php?p=1282300&postcount=3
Typically, if you are replacing caps that are very close to high-heat areas like power resistors, you probably want to put high-temp caps there, especially if they have failed already...
