Punchout Fuses
Tycoonbrad
LAWRENCE, Kansas
The manual recommends:
Main Fuse: 5A 125v
Power Supply Fuse: 3A 125v
Video Monitor Fuse:4A 125v(slow blow) and .3A 125v
The only fuses I can find local are all 250v. Also, I checked Dokerts link for Great Plains Electronics and they only have 250v. Can I use 250v instead of 125v?
The 4A 125v for the monitor is the only one that specifically mentions slow blow. What kind do I get for the the rest of the fuses?
yes you can use a 250v as long as the amp is the same,for all the fuses as long as there fast blow.I never use slow blow fuses.
Iv had no trouble doing this.
But you can find the fuses you need online.
As mentioned, it's perfectly fine to go up in voltage....do not go down. A "fast blow" or "normal blow" will be fine for the non-slow blow fuses.
Edward
