Punch-Out! Dual monitor question.
dethfactor
Donor 3 years: 2011, 2013, 2021
Portage, Indiana
Restoring a PO and have everything pretty much accept the monitors. What originally came with PO? 2 Sanyo EZ20s? I have a few WG 4600's I can put in there but I'm not sure if PO needs inverted color signals like the rest of the Nintendo games. I assume it does but not sure. If so I'll just try to get my hands on 2 more EZ's before I go further with assembly.
Any info would be greatly appreciated.
Thanks,
-M
Punchout uses the same inverted video signals that other Nintendo games do. Use EZ20's or that other Sanyo Z2AW. A lot of Punchout games seem to have one of each, from the factory.
-Ian
Also keep in mind that a Punch Out cab should be wired for only 100 volts AC normally because that's what those Nintendo monitors used. A WG 4600 would need 120 to operate.
