Punch-Out back door
Grbgemen
Lincoln, Nebraska
Can someone please give me the height and width of a punch-out or playchoice back door? Also, how thick is the wood? I need to make one and wanna grab a piece of wood while I am here at work.
It is made out of 1/2" plywood......
Just measured,
52 15/16th tall (from inside that faces the inside of the cab)
23 5/8 wide
the lip on the bottom is 3/8" and about 1/8" deep into the 1/2" plywood
The hole at the bottom is up from the notch(outside of the cab) 2 15/16"'
is 1 7/8" tall, and in 5" from each side........
Here are a couple pics, I know my description isn't the best, if you have any more questions, PM me......
Here is a shot.
It is the typical set up that nintendo put on all the rear doors I've seen.
Looks like a piece of the 1/2" plywood stapled to a 3/4" block on each side of the hole....
