Punch out Audio.. no music
thefader
South Dakota
My punch out cabinet isnt playing the background music and crowd sounds. The other sounds, "Body Blow" and the 1 2 3 counting are fine. What should I check or do? Thanks.
There are volume knobs on each of the monitors. I believe one controls those sounds and one controls the fight calls. Try that, I'm pretty sure I dealt with the same thing on mine, only the other way around.
Turned them both up, same situation. All connections appear to be solid, even though I'm unfamiliar with the wiring. Could this be a bad chip? I switched the audio signal lines between monitors, the lower monitor then plays the fight sounds.
