PSP Help
davin72
Round Rock, Texas
So I have a PSP with CFW 5.50 GEN D3. I went to Walmart and bought a new game ( Hot Shots Tennis) and it doesnt want to load. I keep getting the error code 80020148. Is there anyone that has had this problem and knows how to get this UMD to load up with this CFW.
Please be carefull what you say in this thread so the mods dont delete it. If you need to just PM me.
Davin
It's been a while since I've used a modded PSP, so I don't remember if your CFW is the same as the one I used to have, but try pressing the select to bring up the special menu on the home screen.
Set the UMD driver to sony, which should be default, but when loading games from a memory card, you generally change to cfw or something
That was basically it....thank you. I had change back a setting I had changed earlier but once I did it worked like a charm.
