I have a lethal enforcers cab where the guns didn't work. I replaced the power supply with a brand new one but still no luck even with a steady 5 volts to the guns. The monitor was dimmer then it should be so I tried a cap kit to see if I could get the guns working.
Well the good news is that the guns now work. The bad news is that I can't get the picture to center.
Bob Roberts did not have the exact same cap kit but he sent me one that he thought would work. I ended up using just nine of the caps and just hoping that the nine would fix my problem. Now the picture is hard to get to not tear horizontally and I can only get it to not tear when it is 5 to 3 inches from the side. The second I move the position any closer it tears.
I didn't have this problem before the cap kit. I used a few caps that were just a bit higher in voltage but unless I made a mistake they were all the same uf values.
Anyone have any ideas what went wrong?
