Problem with King of Dragons...issue with battery?
kruuth
Georgia
My KoD is not working right. Is this a CPS suicide issue?
Here is a pic:
no, it's not suicide issue. did you mean with not working right is, the color is wrong? and the picture is distorted?
As mrdion says, definitely not a suicide issue.
More likely a problem with the ROM board, perhaps one of the ROMs has failed or maybe needs re-seating?
Unfortunately... CPS1 sets are a pain in the ass. That problem could be a ROM issue, a C board issue, or even a bad A board. :(
Well, first things first - have you done this before? You need to ensure that you don't bend any pins and that you put them back in the correct way around!
Do them one at a time, ie power off, remove one, check all pins, put the ROM back in, turn on, see if the fault has been resolved - if not move onto the next one - repeat.
This may not of course fix the fault, but it's worth trying as a first easy measure.
Here's a pic of a KoD boardset:
The ROMs that you need to try are all of the large black ones - eight of them in that pic, the ones without labels.
Reseated the rom in the upper left corner. That fixed it. Thanks folks.
Oh, on a side note, that top rom isn't sitting so hot...
