bumpnthump05
Hello everyone, I just picked up my first pinball machine yesterday for $80. Its a 1976 Gottlieb Buccaneer (also known as "ship ahoy"). I purchased it and was under assumption it needed rubber kit and power cord repaired someone rigged it with wire nuts after getting cut. Well i got it home and plugged it in and nothing turned on. Well long story short, i found out the plug itself was bad. So i spliced in a new plug (for temporary) and plug it in.
The head lights up and the tilt light is turned on. I get NOTHING out of the playfield. No lights, no reaction to anything on the playfield. I try to coin up or start a game and still nothing. Well i ended up finding someone that talked about manually turning on the tilt hold relay, and when i do, my playfield turns on the lights but still get no coin up, no reaction on the playfield either. Ive wedged the tilt hold relay on to test things and still nothing. I have turned the score wheel and it does its 120 degree turn and stops. I read something about an ax relay in the head and i manually activate it and it sounds like it resets the score wheel and a relay or two but im super confused. Basically a dead duck. Can anyone give me some advice?
[size=+2]When the tilt hold relay is wedged on, this is what i get.[/size]
Heres some pictures of the machine.
