See:
http://www.pinball4you.ch/okaegi/pro_soft.html
Specifically:
First variant (this is what I'm currently running)-
firepower / 310 241005 add 7-digit displays for player 1 - 4, add version nummber, recalculate checksum
this software is for system 7 / system 6 boards for firepower
New with version 310:
New rules (based on ideas from Marcel):
Spinner skill shoot:
When the ball is in the shooter lane, the spinner arrow will flash a short time (10 seconds)
If you hit the spinner during this time, the spinner will score 5'000 points
Firepower multiball and award sequence:
1) Multiball starts. "Fire 1... Fire 2... Fire 3..." (as normal).
2) Middle stand up target banks are reset (all strobing)
3) Player must hit all 6 standups. Accomplishing this enables all three locks (green "lock" arrows are flashing) and throws in an uncalled sound effect to signal for next step.
4) Player must shoot the 3 balls *back* into the enabled lock holes during multiball to score the 600'000 point award. CPU makes speech call: "Mission Accomplished".
5) Multiball restarts (back to step #1)
The coin specific settings are removed, you get 1 credit for the left or right coinslot and 4 credits for the center coin slot. The coin counters are also disabled.
Second variant (way cool, and something I plan to do at some point. I just need to scare up an extra System 7 MPU board):
http://www.pinball4you.ch/okaegi/pro_softfirepowerdeluxe.html
Details:
New rules (part one):
Four Missions:
The origional rule states:
Lighting "Fire" and "Power" scores and increases "Fire Power" Bonus Value
The key change is after "fire" and "power" are lit, a challenge (called mission) has to be completed in order to receive the "Firepower" Bonus.
Mission start: A mission will start if you complete "fire" and "power". Look here to see a mission start on my pinball. There is a quick show of the mission number and the speech "mission one", "mission two", "mission three" or "enemy mission" and a wipe up of all playfield lights. Then the normal lights returns and then the timer countdown starts.
A sucessful mission will use the normal flash sequence of "firepower" and will advance the firepowerbonus and the speech "firepower".
An uncessful mission (timer is 0 or one balls is lost) will result in unlight of "fire" and "power" and no firepower bonus and the speech "enemy won".
Start out with all 3 "Fire Power" bonus value lights (10,000 30,000 and 50,000) turned off.
A part of the adjustment# 33 is disabled.
During challenge mode:
The orange targets accepts hits (scores 1000 points) but their inserts will not lit.
The same for the power targets.
An "extraball when lit" lamp(after completing 6 or 5 times F-I-R-E) will be stored after the challenge.
The missions:
First mission:
Hit a moving center (1-6) target.
All center targets are dark and one moving light target must be hit.
Mission time 20 second
Second Mission:
Hit a moving power target
All power targets are dark and one moving light target must be hit.
Mission time 25 second
Third mission:
Hit two moving center targets (1-3, 4-6)
All center targets are dark and two light targets (moving between 1-3 and moving 4-6) must be hit.
Mission time 30 second
Forth mission:
Hit center target (between the bumpers)
Light (10'000,30'000,50'000 firepowerbonus) pulsing ascending.
Special thanks to mjmmx for the design of the firepower missions and the concept.
New rules (part two):
These two ideas are from Marcel.
I'm also using the modified Centaur ROM set from the same site; makes it more challenging to keep multiball going once it's started; with the stock ROM's I was ending up with 30+ minute multiball sessions, which while fun, do get old after a while. LOTS of good modified ROM sets.
