What do you value these two cocktails at? The Joust is super clean. I'd rate it an A-. The Defender is pretty average, I'll give it a C+.
Both cocktails have had the monitors rebuilt by Buffet a few years back. The Joust is close to numbers matching, the only oddball serial # is the power supply board (the heat sink and transistor part does match the serial of everything else) . All of the other boards, monitor, transformer and cabinet are serial # 606924. The Joust doesn't have the typical "inspection" stamp anywhere on it. I talked to Lonnie a few years ago and he thought that was weird.
The Defender is average. Not much more to say about it. Both of these cocktails are rock solid and will run for days.
Thanks!
Thanks!
