dr. mr. pants
hey all,
what is a fair price for a working space fury?
thanks!
thanks!
Fully working it's worth $552.97
SteveJ - specializing in low-accuracy, high precision estimates since 1968.
Does the G08 work in it? If not, then its worth a fair amount less. If the G08 has been rebuilt and is rock solid, it might fetch 5-6ish? You dont see many of those for sale. Also those are the heaviest dang cabs..
amazing! who are you, kreskin?
actually, got it for $300. not a great deal, but fair.
300 I wouldnt sell mine for less then 1,000 Out of the 9 years I have been collecting I have only saw 2 in the local area.
That's a great deal on that game.
There's also a sega multikit coming out now that allows you to play other sega vector games.
when is that coming out? who is making it? awesome.
As of today it is now worth 553.14... slight increase in the market share over the past couple of days.
wow 300 is a good deal..FIRST thing I would do is pull them monitor, clean it, make sure the fan is working. Pull the aluminum heat sink on the right, clean it, and make sure it doesnt have ANY 2n37xx transistors in it. If it does, order the correct ones (Bob has them, but puts the wrong ones in the cap kit). Every G08 Ive fixed, ok its only been a few, has had the 37xx transistors put in it. They will blow up and take everthing in the output section, well, everything BUT the fuse... I cant believe how much heat a < 2amp device can generate.
Andrew
