Preorder: BERZERK JOYSTICK Handle
chips4sle
Spring Grove, Illinois
Yes, I am double posting this...
It got moved to the "restricted" section and I do not know how often that gets visited.
Sorry if I offend anyone :)
Here is the much anticipated BERZERK Joystick reproduction…
**The handle is Aluminum & Powder Coated Black. The Shaft is Steel.
The Joystick (handle/shaft) is $75 plus shipping.
**It will fit into a Happ Controls Perfect 360 Joystick base. No hole for the roll pin. That was an additional cost that we did not think was necessary.
Those can be ordered from us for an additional $85 plus shipping.
**Wood control panel bottom to work with Joystick / control panel, comes with the T-Nuts, is $20 plus shipping.
All of this will work with cnlmoore's control panels.
We will need a minimum order of 75 joysticks to make the project. If we do not hit 75, any pre-payments will be refunded.
We will be taking pre-orders until Sunday, June 10, 2012. If we hit 75, then the project will take approx. 30-45 days to complete.
Attached is a picture of the prototype joystick.
Any questions can be directed to: [email protected]
Please email or PM your order and will send you an invoice.
Thanks…
(wood picture stolen from retroactive )
Wow... minimum of 75 for the project to get off the ground? Are there even 75 working Berzerk cabs in the world? ;) Good luck with it though, it's always nice to see these kind of projects.
What do you mean about the roll pin hole? And I assume this works with the Perfect 360 only, not original Bat bases, right?
DogP
considering that chris has done 3 runs of panels and there was a run before he started doing them. i just thought this would make a great addition.
So this has been fully tested and kicks ass with the perfect 360? Is it solid AL? Or hollow?
How about annodizing them. Might provide a smoother finish.
hi
its roughly the same weight as the origional
i figured that power coating would be better since it will fill in any imperfections
yes i have tried this on my own game and it works well in the 360 base
by the way are either of you buying any to make the project go forward
hi
Could we get a discount if we get multiple?
hi
Strongly considering it. I bought two of the repro CPs.
We are moving nicely toward our goal. We have decided to do the project either way.
Please keep in mind, if you do not preorder the joystick, the price will go up after the preorder date.
Thanks! Get those order in, only a couple more day.
We are looking to do the TEMPEST SPINNER CAP, but it just depends on how many handles we sell to fund that project.
