Only thing with paint strippers - sometimes the nasty stuff can get into crevices or cracks in the wood and spoil the finish later. Gotta make sure you get it all out or neutralize the stuff. I used stripper on a couple of projects, then decided I like just using a sander better. Though more crap is airborne, I don't have to worry about the goopy mess.
Gotta make sure you use quality paper, like the 3M gator stuff, and start with 80 grit. If you start with the wrong grit, it will take forever. Usually the original finishes were pretty thin. I don't know that that applies to the Berzerk cabinet though-
