PP2 Screen
emperormax
Donor 4 years: 2015, 2023-2025
Maryland
Anyone know what causes this? Game seems to be running fine, it's just that the graphics look like this on the screen.
Max
What is your skill level? That could be anything from a "simple" monitor adjustment to a full-blown chassis overhaul.
I've re-capped monitors, do you think I should try that first?
Definitely check your sync. It looks like you might just need to adjust H Sync/Hold, but it could also be something like a bad solder joint, dirty connector, etc on the sync pin(s).
DogP
