PP2 - battery corrosion
modessitt
Austin, Texas
Picked up a PP2 cab that was a MAME driver and is now going to be a PP2. Among a bunch of other parts I'll need, I have battery corrosion on the boardset. I plan to pull a bunch of parts, clean it all up, replace a bunch of chip sockets, etc.
What I want to know is - are there any chips, etc that I won't be able to replace, so I should be extra careful about pulling out and cleaning?
I understand that if I don't get it all cleaned up and traces repaired first, that I'll blow up some ARII's when I put it all together.
Anyone got a good wiring harness or steering wheel optic board? I need a new sterring wheel, also, as this one is bent a bit....
mod- i have a cp with wheel and opto-
however the metal for theshifter was cut out to accept some other shifter at some point..
unsure if the opto is good but it looks ok...
could strip the wheel and opto off the cp for ya..
also i do have a couple dead/hacked pp1,pp2 boardsets so if you need some chips in particular lmk..
there are a coulle transistors down there but they are all common ones...
