PP Reset
toro1966
Poland, Indiana
Have a PP and the game works fine and the picture is great. Only issue is that every few minutes - when the game is not being played, it will reset...and go back to the attract screen. Any thoughts?
Talk about a can of worms...
Check for good connections on the edge connectors, including the board interconnects at the other end of the boards.
Next... Check for good voltage at the board.
After that, check the area around the battery for corrosion damage. There are some parts around that going to the enable lines on a 2kx8 SRAM chip. If those are having connection issues you'll get random resets...
Thanks! I'll check those all. Appreciate the assist.
