PP Brake Shows On Test, But Does Nothing
Embalmo
Texas
Hello folks. I've seen tidbits here and there, but not enough for such a noob as me. I've got a cockpit PP with PP II boards. It actually works reasonably well, but the brake does nothing.
The brake micro switch checks out on the test screen, but does nothing in game play. I know that I may never use the brake in game play, but I would like to have everything functional.
Thanks,
Embalmo
when you press the brake pedal in test mode what does the number change from and then too?
Thank you for responding! On the test screen it starts at zero and displays EB when the brake is pushed. Also, depressing the brake pedal causes the acceleration audio to cease while in test mode as if it's braking.
I thought that it would be a dip setting because the upright version doesn't use a brake. I encountered a similar problem with a Road Burners sit down that would only allow the handlebar pot and not the bike seat tilt pot for control. It turned out that it was set for the upright version.
Thanks Again,
Embalmo
documentation says that the brake should read FF when applied. Is the brake a switch or a pot? I'm thinking switch but I'm not sure.
Might be a long shot. Short the two wires manually (as in not with the switch) and see if you get a different reading in test mode.
