andykmv
well, if that is the only option, i guess that i may have to go that route. but one of the main reasons that i pulled the taito power supply was that with all of the wires in and out of the transformer, i wasnt sure which input wires would power which output (if that even matters)..
edit: I think that I figured out another option. from my previous experience with getting a transformer for my payphone, i should just be able to get this 12.6 volt center tapped transformer
http://www.radioshack.com/product/index.jsp?productId=2102700
with only using one winding, I will have my 6.3 volts.
comments? confirmation?
Edit#2... I got a 3amp transformer. Part 273-1511
perfect. you may also have some lights behind the instruction card behind the bezel. trace the green 6.3vac lighting wires for the marquee up and over the speaker panel, if they were installed that is. dont forget to check/replace those bulbs too!
