Powering Naomi's with ATX PSUs
Seems like if someone were to take the above mentioned item and add the ability to adjust the 3.3V and 5V outputs to get them well dialed then it would awesome to use.
Not a DOC power supply. Its just where the wall voltage enters cabinet.
Use the Happ 44-1095-01 or something similar. Or just make your own PSU with three little individual 3.3,5 and 12 AC/DC enclosed units with adjustable outputs. Not difficult to do this either.
sorry to resurrect this thread but the happ is dificult to get where I am, are you saying i can just get some separate switching mean well power supplies for the 3.3 and 5v?
I'm trying to power a net-dimm triforce but the atx psu that did run the original non net-dimm triforce will not boot up the new triforce. 5v line reads 4.6 and 3.3 line reads 3.11
These will work fine. I have a one off PSU built by a friend using three units like this all enclosed in a steel box (also one off) and it works great for anything I power up thru Chihiro. You can get as creative as you like doing this. Mine has individual PSUs, individual displays for DCV and current draw, power switch, big Noctua fan across back. You don't have to go to that extreme to make something that will work fine for N1/N2 just as long as you can set the 5 and 3.3.
Excellent, thank you so much for the reply! Will order them right away
Noob question: can / should you bridge the grounds on the dc out side?
Where are you looking at the Happ psus? There's a few sites selling them. There was no issue shipping to me in the UK, so Europe shouldn't be a problem unless the Netherlands has some postal issues I don't know about? (Sorry, just googled the arcade in your profile picture.)
Yep netherlands is correct. When i said hard to get i meant slow / expensive really. I can only find us webshops, where did you order from?
The mean wells i can get next day delivery and free shipping :)
I ordered from Betson Imperial Parts. Cost about $228 for 3 PSUs and $60 of that was UPS 3-day shipping. Took less than a week to get here.
In my experience at least, in the arcade world you need to get rid of the next day delivery mindset. I agree that it's convenient and nice, but the US & China is king for arcade equipment (and Japan to a slightly lesser extent). So if you're not in those countries, you gotta wait for shipping.
But all in all it's your choice :) I could have gone your route and made my own PSU out of smaller individual units, but didn't feel confident doing that. So, I paid more for the convenience of getting a "plug and play" solution.
betson only stocks the newer version of the Happ and those go for 190 dollar a piece plus shipping. That makes the price difference quite big with the meanwells
ah I misunderstood the site in that case, but nevermind already ordered the other parts. Good to know for future issues though
While this is bumped, anyone know the correct way to dial the adjustment for the 3.3v and 5v?
Ive been told to adjust when powered on with no load, then again under load. Should I adjust the voltages to be slightly higher when going in the Naomi? (ie 3.4v)
not as pretty as the unit above but it works great, the new triforce booted up instantly.
I set the 5v and 3.3v without load first and then checked them again with everything attached (no difference). I set everything as close to perfect as possible, not slightly higher
Thanks! I was wondering about the "setting it higher" thing since I've heard of it in several places, because the voltage can drop. So it'd be 3.3v going in at the power plugs then 3.25v by the time it gets to whatever needs it.
