power ?
rony2211
weaverville, North Carolina
i have a crusin usa sitdown when you power it on the header comes on the monitor makes
noise like its getting power. but no lights on the power board or the pcb,or the switching power supply im thinking its the switching power supply. what do you guys think and are all the switching power supplys the same ? thanks Ron
Depends on which power supply is in it.
If I recall correctly, the Cruisin' USA has a battery on the board that goes dead, and when it does, it won't power up the computer power supply unless you reset the CMOS.
You can check the power supply to see if it has a bypass for the power switch sensing (if it is computer style) or check the battery to determine which is the problem...
Not sure if there is a jumper. I can't remember. I think one of the versions of the Cruisin' has a keyboard connection that you use to enter the CMOS menu. But first, find the battery and see if it's dead or not...
