Power switcher wiring config/ hookup on All Points Bulletin A.P.B.
john2654
Donor 3 years: 2011, 2020, 2024
Rhinelander, Wisconsin
The switcher power supply is dead in my APB. I'm gonna put in a computer AT power supply now just for testing.
Need to know the wire config.
Currently:
Dark brown & light brown w/ white stripe: in -GND
2 Red in: +5V
Dark brown: in FG (frame ground) --- wrong spot???
Loose Red w/ white strip: ???
Black and white wires are AC, I know.
http://forums.arcade-museum.com/attachment.php?attachmentid=65123&d=1300329952
Just found the schematics for the APB, looks like some wires were wrong.
Correct config:
Red/white= + Sense
Red= +5V
Red= +5V
Brown= Ground
Brown= Ground
Brown/white= - Sense
OK, so that probably explains why the switcher is dead.
But where do the + & - Sense wires go??
+Sense with +5V & -Sense to Ground (-)??
Hooked up the 2 brown wires to grd (-5V) and the 2 red wires to +5V on the AT computer power supply. Works great.
I left the 2 sense wires disconnected. Don't know if I need them or not, but it works fine without them.
Now I need to fix the APB Triac board because the red light is always on, but the blue functions correctly by blinking when the siren is going.
