I need a power supply for a california speed deluxe cabinet. I know its normally a 80-20167-0 like happ sells and the manual states. But the connectors are completely different. The connector is 12pins (3x4) instead of the 9 pins (3x3)that its states and it uses a secondary connector as well with 6 more pins. The big connector is almost identical to the sanfrancisco rush power supplies.
I have no idea what power supply would fit this set up. Looking around the harness is not cut or hacked so why is this different from the manual?
Also the wiring and cab is slightly different than the manual such as theres no power switch on the top of the cab like it states. Theres not even a hole for it!!
Pics are not the best quality....let me know if i need to take better ones
