AllenBomber
i picked up a Super Breakout machine that wasn't functioning. I pulled open the cab, and someone botched the wiring at some point. It looks like they tried to drop a different power supply in there, but rather than using molex connectors, they just jammed wires into connectors. I tested the power supply and it seems to work, but I've got some interesting results. The 12 pin output terminal of this power supply gives me the following in reference to case ground:
1. 30VAC
2. 6VAC
3. 19VAC
4. 26.5VAC
5. 0VAC
6. 27VAC
7. 9.5VAC
8. 6VAC
9. 14VAC
10. 22.5VAC
11. 4VAC
12. 4VAC
Now if I call pin 11 my ground, I get different numbers, and a DC output on pin 12.
1. 36VAC
2. 10VAC
3. 16VAC
4. 32.5VAC
5. 3.5VAC
6. 25.75VAC
7. 7.5VAC
8. 3.75VAC
9. 19.5VAC
10. 19.5VAC
12. 14.5VDC
The game came with a manual, and it looks to me like the power called for by the board is 16.5V CT, 16.5VAC, 25VAC, and 25V CT, and +10V Unreg. I assume that CT stands for Continuous (DCV) but I'm a bit iffy on what they mean when they call for +10V Unregulated. Also, to me it looks like the power supply I got with this cabinet won't work because I don't have anything close to 25VDC, but please correct me if I'm wrong. Can anyone point me to a power supply that would work?
1. 30VAC
2. 6VAC
3. 19VAC
4. 26.5VAC
5. 0VAC
6. 27VAC
7. 9.5VAC
8. 6VAC
9. 14VAC
10. 22.5VAC
11. 4VAC
12. 4VAC
1. 36VAC
2. 10VAC
3. 16VAC
4. 32.5VAC
5. 3.5VAC
6. 25.75VAC
7. 7.5VAC
8. 3.75VAC
9. 19.5VAC
10. 19.5VAC
12. 14.5VDC
