MMAO - Parts: Power Supplies (pulled from Naomi set ups)
stayjacked1
Ontario, Canada
These were pulled from a few cabs I had running Naomi set ups. Not your typical sun power supplies. That you usual see. Comes with some Naomi wiring with them. If anyone can shed some light on these that would be great. Open to offers on these. Shipping will be around 30 dollars.
Looks to be a standard PC power supply, or a Peter Chou maybe....with a simple pass through block that's been double-sided taped to the top, and then wired out to naomi power connectors.
Basically, it looks like you got some "I don't have spare SUN psu's, so I will do whatever I can to make it work, and keep it from frying anything" solutions. I cant say much, I have used a PC psu in place of a SUN...but I did pin mine direct to the connectors....that bypass block can be a headache as its not labeled.
Not trashing on what you've got...they should work fine on a Naomi, as long as they psu's themselves work. Just definitely a rigged kind of situation, and definitely not factory.
Thanks for the info. The bypass block is actually labeled. I figured they were computer power supplies but just wanted to double check just to make sure. Didn't want to sell something I wasn't 100 percent on. I appreciate the feedback.
