power problem
HAVASUGAMEMAN
lake havasu city, Arizona
ok think i know the answer to this but want confermation,i have three pins out on location and all three are having the same problem,90 % of the time the game will reset in the middle of the game. they added more stuff onto the power strip that the pins are plugged into.i think there is to many things on the circut,can that be the answer? i just cant unplug the new shit they added to prove it! thanks
Pins are very sensitive to power , if the other equipment drops the volts even temporarily it would cause the pins to reset . What else is plugged into that strip.
went back and checked the volts only getting from 106 to 110 and there is an open ground on the circut. not sure thought i saw here somewhere that the pins need atleast 115 volts? there are a 3 pins and one buck hunter and also a skill game along with whatever else they are running in the kitchen and bar area on this breaker. i know way to much just cant get the bar owner to understand that.
To try to convince him, use words like:
"liability"
"overloaded circuit"
"electrical fire"
"code violation"
RussMyers
