POT Question :)
CamaroMurph
Naperville, Illinois
Can I replace a 300K Ohm POT on my Nintendo pcb's with a 500K Ohm POT? Is it better to use one with a wider resistance range or narrower if the correct one is not available?
Murph
A 500K ohm can be used, but you'll find that your turn radius for adjustment is a lot smaller than before, and it might make it harder to dial it in....
