Hello all,
I did my first cap kit on my Sanyo 20EZ today, I used the arcadepartsandrepair deluxe kit, as well as a replacement filter cap.
Before, the monitor had severe horizontal blooming/ghosting when displaying colors on dark/black backgrounds. After the cap kit that issue is resolved and picture looks decent, other that it being really offset horizontally. I tried tweaking the H center pot and that did move the image, but not nearly enough to correct it and make the entire image visible.
I double checked all caps had the correct polarity, and reflowed some joints that I thought might need it. No change sadly.
I then did some research and it was looking like adjusting the width coil could fix the issue. I don't have monitor adjustment tools, so I 3D printed a 2.5mm allen wrench with PLA to try to safely adjust it. Rotating it clockwise and counterclockwise did not appear to have any effect, but I'm not sure if that's the fault of the coil or tool, as I've never tweaked a width coil.
Any pointers on what I should be trying next? The pattern in the attached images is being displayed by a CraftyMech TPG. I have the monitor attached to a spare Nintendo isolation transformer which is then plugged to wall power. B+ is reading at about 107V.
Thanks in advance!
Thanks in advance!
