Possible tube swap with a Hitachi A48AAJ00X ?
wolfeel
fortuna, California
So I have a Hitachi A48AAJ00X tube with the following chartaristics:
10 pin
3.6 ohms (red/blue)
54.9 ohms (yellow/green)
uses a CR23 adapter
Looks like the same pin location and neck size as my K4600 tube. From what I have read it seams like I could use this tube with a K4600 chassis but could not use the Hitachi's yoke (I would need the K4600s yoke). Correct?
Is this yoke good for another chassis?
Thanks for any help!
You will need to swap the yoke.
I don't know of any arcade monitors that use a yoke with the readings of your existing yoke but it may exist...
Damn close to a G07 and close to a 20EZ and other High Impedance Yokes.
FYI, yolk is the yellow part of an egg.
