Positive Feedback Guidelines
admin
Administrator
Staff member
California
This forum section is for posting positive feedback for others.
The iTrader feedback system is primarily aimed at getting a rapid view at a user, how often they trade/buy/sell with other users, and how often such transactions are successful and positive. These sub-forums are designed to allow users to (optionally) post more detailed information about transactions.
There is a grandfathered very long feedback thread archived here. All new posts should follow the following guidelines, which are designed to make it easier for members to view user feedback without having to search through a 500+ post thread (or search to do so).
Viewing threads in this section
Threads by default appear in reverse chronological order -- that is, newest posts are listed first. You may find it helpful to change the order to alphabetical. This would allow you to easily find all posts related to a particular user (you can also do this with the 'Search' feature).
Posting threads in this section
*** PLEASE DO NOT POST POSITIVE FEEDBACK OR WARNING THREADS UNLESS YOU HAVE PERSONALLY HAD A POSITIVE BUY/SELL/TRADE EXPERIENCE WITH THE PERSON OR CAN CLEARLY DOCUMENT (IN YOUR POST) WHY WHAT YOU SAY IS CORRECT (IE: LINK TO AN EXTERNAL PAGE OR NEWS ARTICLE).
*** THREADS WITHOUT EXPLANATION ARE OF LIMITED VALUE. IF YOU DON'T WANT TO TAKE THE TIME TO EXPLAIN, USE THE iTRADER RATING SYSTEM INSTEAD.
Thread Titles:
***Thread titles are subject to strict rules in order to make them easy to sort though alphabetically, and to limit inflaming words in the titles.
*** All posts should begin with the Username of the person you are rating. If the person does not have a Username, you can use start with their real name. If you know both, just use their Username.
*** All posts should contain, whenever possible, the U.S. State (if in the US), or the Country (if foreign, including Canada), whenever possible, after the username in parenthesis. For example:
"GoodGamer (CA) " - CA=California. 'S' is explained below.
"GoodGamer (Canada) "
"Doe, John (NV) [T]" - A use of a real name when a username is unavailable.
*** Posts should include a
Code:
 at the end of the title whenever possible:[INDENT]"[S]"     - Person you rated was the seller
"[B]" - Person you rated was the buyer
     "[T]"    - Deal was a trade, or part cash and part trade.[/INDENT]*** You may post a 'redirect' post beginning with a title beginning with a person's real name or a company name with an arrow " -> " and then their username, followed by '[Redirect]'. Including the location in redirects is optional, but if it appears, should be after the username. Example:[INDENT]      "Doe, John -> GoodGamer (CA) [Redirect]"
     "John's Vintage Arcade -> GoodGamer [Redirect].
[/INDENT]*** Redirect Posts should contain nothing inside of them than (at most) a neutral statement that "John Doe" or "John's Vintage Arcade" (for example) is known on these forums as "GoodGamer"
[U]Thead Content:[/U]
 In your threads, PLEASE include the location of the person you had a problem with.
If the transaction you refer to was more then 6 months old, you [B]MUST[/B] include a time reference in your post.  The fact that the transacstion  happened years ago doesn't make it less valid, but the fact it is an old matter must be disclosed.
[U]Responses:[/U]
Responses should generally be only by the poster or the party being discussed, or by people with direct knowledge of the particular situation. If you are not a party to the specific transaction you may post advice or similar messages but please keep the conversation to a minimum (if this doesn't work, we will restrict the policy further).
If you also had a previous pleasant or had unpleasant experience with the same person, don't add it as a response to someone else's thread already open--- create a new one. Responses can get buried, while, again, a cluster of threads all beginning with the same username (ie: "GoodGamer") will tend to get noticed.
