dkblue
Has anyone solved the great "can you run a 2 board Popeye with a Donkey Kong power supply" debate?
I've seen a few threads on here but none seem to have a definite resolution. Some people say yes, some say no.
There's also conflicting information out there about what voltages are and aren't used. I'm pretty sure every place agrees that the -5V isn't used for Popeye. However, one big question is the +24V.
If you look here at http://www.arcade-museum.com/pinouts-game/9090.html , you'll see that there is no +24V on pin 20. However, if you click on the manual link ( http://www.arcade-museum.com/manuals-videogames/P/Popeye.pdf ), it shows +24V on pin 20.
MikesArcade.com shows the +24V on pin 20 as well (http://www.mikesarcade.com/cgi-bin/spies.cgi?action=url&type=pinout&page=Nintendo_Classic.html).
My plan is to use a DK3 harness, remove the -5V and +24V and see what happens. Everything else (video, sound, etc) seems to be the same or really similar.
Has anyone tried this? I saw someone say they smoked a Popeye hooking it up to a DK ps, but I don't think they took the time to remove the -5V or +24V.
Any suggestions? If all the voltages are there (and Donkey Kong shows there's +24V as well http://www.arcade-museum.com/manuals-videogames/D/dkong1.pdf) and it's wired correctly, is there any reason it wouldn't work?
