My Popeye finally went. This is what it displays now. Before, it would display this now and then when powered up. I would simply turn it off, wait a few seconds, and power it back up, and things would be fine again. Not this time.
I checked the power supply and the board is getting the 5v. I believe that's all the board uses, outside of the 24v that goes to the coin door, for the coin meter?
I tried to reseat all the eproms(twice), and checked all the harness connections(even the ribbon cables) to make sure they were seated well. I also looked over all the solder connections on the solder side of the boards to see if there were any cracked solder joints. Every thing looked good. This is beyond the scope of my knowledge now. Does anyone know what it might be? Any insight would be appreciated. Thanks.
