popeye monitor adjustment
PacAttack13
Omaha, Nebraska
Im having problems adjusting my popeye monitor. Is there a pot for vertical positioning for a popeye with a Sanyo 20EZ monitor? Picture looks great but when I adjust the vertical size if I make the picture stretch all the way up and down on the monitor you cannot read your score at top and if I adjust so you can read your score at top with the vertical size I will have a 2-3 inch gap on the bottom of the screen. Your help would greatly be appreciated. Thanks.
Is there a way you can post a picture and show me exacty where this jumper on the chassis is I would really appreciate it. Thanks. :)
Circled in Blue
there should be a jumper on the right of that pot covering 2 pins, shift the jumper to the other position. If all 3 pins are open, then the jumper has been removed and you will need to make one of your own.
ok I switched the jumper to the other pin now what? It didnt seem to move the screen down any when I moved the jumper to the other position.....
