tester007
Starting to try and piece this together in the cab I have.. bought this 'kit' which is missing a lot of pieces/wire. The cab I have to go in is completely gutted. The wiring I got with the kit is just the main piece... goes to the board stack, the control panel, and the power supply box. There are I think 6 other molex plugs hangling off... I have no idea what is for what... I looked in my DK cab and nothing seems to be the same as far as even throwing this is a DK cab with DK wiring.. the ribbon cable to the monitor for instance I assume goes to the molex on the main harness that has 6 plugs, whereas it goes directly onto the pcb on the DK with a flat ribbon connector.. Is there any wiring diagram around, or good pics of the inside that shows the wiring that anyone has?
