Pool Sharks
katoskave
Permanently Banned - Uses multiple accounts to sca
Alaska
So my Pool Sharks had some issues but replacing the 24v cube style relay on the aux driver board fixed the quirk. However after quite a few hours of play the relay has a burn mark on the left side of it and now the machine has the same issues again. Any ideas? what all is connected to the relay? Any advice?
Replace the relay again. Disconnect the knocker, and reroute/remove the ground strap on that side of the backbox. Or, check the ground strap throughout the game, make sure nothing is pinched. There was a production issue with pool sharks, where something causes interference between the ground and certain solenoids (usually the knocker), and the interference burns up the "c" side of the relay.
Also make sure your power cord plug has the ground prong on it.
Mike
Check that... Don't remote the ground strap, but do inspect it carefully.
Mike
