Pool ball as a replacement Happ trackball?
pool
i have seen it done alot with the old atari trak balls, should work, maybe even kind of a cool upgrade from plain jane color
I have done it as a confirmation of a worn out ball. I used my dad's 8 ball. You can get them at most pool supply stores for about $5. Switch them out every once in a while for a change of pace.
i like mine in my centipede UR. it's a red #3 it makes it stand out. every body that play's it always comments on it.
but you will need to open it up and clean it from time to time pending on how much use it gets. the rollers will strip the clear coat off the ball.
Peace
Buffett
no
remove track ball from cab, undo 6 screws, pick out old ball (trash sell or keep it) put new ball in, re-insert 6 screws. install back in cab. ENJOY!!!!!
Hope that helps:D
Peace
Buffett
