POLL: Hardest machine to install Cliffy protectors and/or rubber
Deadly
Gresham, Oregon
Jeff Rivera (JAR155) warned me about how painful it was to install Cliffy protectors on WCS94. Man he wasn;t kidding. I just finished up adding the protector set and my god am I glad that's over with. I cannot believe how many freaking components have to be removed in order to do it. And even changing the rubbers out was just a freaking headache on this game. The only good thing that came out of this is I was able to give the playfield a complete cleaning and the rubbers should stay white and usable for a long time to come.
So - what machine/s do you feel are a major pain to either:
1.) Add Cliffy protectors
or
2.) Re-rubber
I have not added many so no real issues.
or
2.) Re-rubber
I would say alot of the early DE/Sega pins with all the layers you must peel away. Star Wars, TFTC ....
My vote is for Rollergames as it is the only pin Ive ever shopped, so I learned alot this weekend
(Mainly on how NOT to do things)
Ramp was a major pain to remove along with all the side plastics, but it did go back together ALOT easier than it came apart...
I also found a ramp diverter that I was unware even existed!
Now what to do with all these extra screws?!?!?!
I always say that if you can put something back together and have extra screws, bolts, nuts or washers and the game works properly then you out engineered the orginal engineer :)
I had one screw left over and after I located the postion it was needed - I would have to remove a ramp and a mini playfield. Bah - I'm leaving it out heh.
