police trainer gun issue
Raiden_2112
Dallas, Texas
Just cleaned the optical lense and sensor.The gun will shoot normal for awhile then shoot all the way on the bottum of the screen.What could cause this?
standard gun checks are those.. and check your voltages..
also, clean the monitor and glass... you have a mirror on this one? if so..
clean it too....
and you can try turning your brightness up a bit and try it... make the room darker...
and try swapping the gun to the other side and see if it still happens...
i vote for wire shorting out inside the gun cable or cold solder on the opto board...
is this a standard happ 45 caliber type gun?
is swap gun connectors just to make sure you dont have a pcb issue...
