Just started happening. The spinner started acting up....
When you put the ball in play with the plunger and it activates the spinner, the spinner rotates and advances the points from 25k to 100k and continues cycling until the spinner starts to come to a halt.... this is normal... but when the spinner can no longer rotate 360 degrees and just pendulum's back and forth, the points continue to cycle until the motion stops.
Attached to the spinner is a wheel with a cut out that activates the point cycle. I've cleaned the wheel and the part it fits between. I've checked all connections on the tiny circuit board.
Any ideas? I don't even know where to find a replacement circuit board for this piece if it needs replaced.
