POLICE Force Pully Mechanism
DreamTR
SMYRNA, Tennessee
I can't get the locks to read because I think the car goes forward, but not backwards very well. Any Idea if anyone has the replacement part for this or what I need to do? I think that is the reason why it won't read the lock after it says LOCK 1 and hit it up the right ramp to get it to that section of the playfield.
if the car did not go backwards correctly, it would never reach the limit switch and the game would have an Error Warning when powered up. your problem seems to be a simple switch problem by the sounds of it, so far. go into Switch Edges in the test menu and see if manually putting the ball up there activates the switch correctly and completely.
Mine did something very similiar. Seems like it came from the belt being loose. Not sure if the sensors factor in to that. But once I tightened up the belt, it moves like it should again.
