Police 911 2
Pachi1991
Hello everyone, I'm a new member and I'm looking for some help. I have a police 911 2 that I've had for awhile and the light gun is working incorrectly, you can fire the gun and the screen will flash but you don't land any hits. We did try the gun on another police 911 and the gun still doesn't work.
I would like to know how to convert a happ 45 to use in its place. I've scene
other guys online do it but they don't explain how they did it. Like how do you make the adaptor for it. Any help with this would be great and thank you
I don't have a picture of the conversion, but from the manual you can see which pins go to which connectors. And I attached the pinout from the Happ manual.
Basically, there's a two pin connector for the gun trigger and a 3 pin connector for the gun sensor (plus a single pin Earth GND). The Happ gun uses a single 4-pin connector. To use the Happ gun, I believe you'll want to connect:
Happ pin 1 (Red) to the Red wire on the 3-pin P911 connector
Happ pin 2 (White) to the Purple wire on the 2-pin P911 connector
Happ pin 3 (Black) to the Black wire on both the 2-pin and 3-pin P911 connector
Happ pin 4 (Blue) to the Yellow wire on the 3-pin P911 connector
DogP
