Any standard resolution 19" monitor will work. Pole Position uses negative sync, which is very standard. Remember though, that the pinout of the original Matsushita monitor was different - negative sync in the same header as the video signal. This is different from most other monitors, which have the negative sync on the little three pin header separate from the video signals. The Pole Position wiring harness has provision for both - there is a quick disconnect in the sync line between the three pin connector and the six pin connector. When using a standard monitor, you must disconnect this, and hook both connectors to the monitor.
-Ian
