Pole Position Ram error 6..
rcoonjr
I have repaired my board before. Working great until the other day I get a Ram Error 6... I've changed out the ram with a known working... so I'm at a loss... Has anyone ever seen other issues that can trigger a ram error 6.
Worse case who is good at working on these boards..?
Check the /OE, R/W, and the /CE lines on the RAM chip for normal operation.
Which RAM is this? If this is the one near the backup battery then you probably have corrosion damage affecting the enable lines for the chip.
I bet your right... my board worked great until the other day... and it did have acid damage (what board doesn't)... I'll check that over. thanks!
